Old Fri, April 2nd, 2010, 01:20 AM
Keeblerz28's Avatar
Keeblerz28 Keeblerz28 is offline
Keeblerz28 has a little shameless behaviour in the past
It is not that the oil breaks the sensor, the problem is the oil is said to coat the sensor and mess up the readings.
I don't think you clicked any of the video links on that page I linked earlier...
Out of 107 sensors returned: 65 functioning properly, 19 completely dead, 23 malfunctioning. Of the 23 malfunctioning, none had any evidence of k&n oil.
Mass Air Flow Sensors Intro & Test Results Summary
Test bench: 1000 CFM for 3 days straight using a 30% over-oiled filter = No oil loss from filter.
Can Oil Come Off Our Filters? High Airflow Testing & Engine Air Filter Dynamics
Dunking the MAF in a beaker of oil, initial readings were off, but sensor returned to normal operation after a few cycles.
What Does It Take to Foul a MAF Sensor? Extreme Testing
I think this myth is what Adam and Jamie would call:
BUSTED!
2008 F150 XLT SCrew 5.4L FFV 4x4 3.73LS 5.5'
Chrome Pkg, Edge Evo (out to PHP), K&N 63, Custom mounted Troyer Performance E-fans, Truxedo Lo-Pro cover, Line-X bedliner, Passport 8500 X50
