Thread: Dyno Results
Old Fri, April 2nd, 2010, 05:54 PM
Originally Posted by shotgun View Post
While you are definitely higher than stock , you can't determine your total hp by simply adding the hp for each individual mod.
I recall a Groovy Chick post where she said that if you have a programmer with a custom tune and then add an intake, you will only get about 1/2 the intake hp. She didn't offer a detailed explanation, but she did say it came from the Mad Doctor.
Also remember that most time the mod 'advertised numbers' are at the crank, not RWHP.
The numbers advertised on the website are at the wheels
· Gains of up to 35 HP and 45 ft/lbs (5.4L 3-Valve engine)
This is the 91-93 oct perf tune.
· Gains of up to 25 HP and 40 ft/lbs (4.6L & 5.4L 2-Valve engine)
This is also a 91-93 oct perf tune.
Adding a CAI to the equation will only get you about 6hp more.
