Old Fri, April 2nd, 2010, 07:00 PM
Originally Posted by Keeblerz28 View Post
As for 3rd party testing, how about the 107 supposedly defective sensors that were returned to them, 65 were totally fine! They sent the 23 malfunctioning ones to an independent lab (3rd party) to examine and determine contaminants. NONE had k&N oil on them.
There's no question that many automotive "Technicians" are merely parts changers, with often inadequate diagnostic training if any at all. I don't doubt that a number of sampled MAF sensors we completely fine and were replaced with the "Well, let's replace it and see if it fixes it" approach.
I think the point being made is that K&N was the party that was handling the testing (at least as far as which "independent" company handled the testing) as well as handling the information on their results. With this in mind, it's possible (although I'd hope unlikely) that they could intentionally obfuscate the facts in their favor. I think it would be more credible if a fully independent test, of which K&N had no control whatsoever, was done.
What about the millions of other filters they have sold over the years? Just think of how many millions of miles have been driven with their filters? How more unbiased a study do you want?
I can't offer any opinion on that without case studies of applications, vehicle types, induction systems, maintenance procedures, and about a zillion other things that would have any bearing on this discussion.
I have a technical background, I work in a lab, and I do a lot of testing according to standards. So I can appreciate when a company spends the time to do the R&D, with a dedicated test fixture, with annually calibrated instruments. You won't even find that at Mythbusters...
I can appreciate your work environment and training, and with that in mind I can understand how people can be opinionated, especially in regards to supporting opinions with empirical data. Again, if the testing was handled entirely by a third party, then I would have a better feeling about the results. Because K&N was so involved in the testing, it leaves room for doubt.
For example:
A few years ago, Ford was reflashing 6.0L trucks with updated ECM/TCM/FICM strategies and IMMEDIATELY (as in before they even left the parking lot) customers noticed a loss of performance and subsequently noticed losses in fuel economy. Ford, in response to these complaints, did study of these complaints and this was what they had found:
http://www.gopowerhungry.com/Downloads/6.0L Fuel Economy Test.pdf
Apparently, it's Ford's opinion that there is no problem with the updated strategies and that all the customers that have lost performance and fuel economy must be suffering from some sort of mass delusion. Just because the manufacturer claims it, doesn't make it so.
For what it's worth, I have PERSONALLY removed MAF sensors from vehicles that had oil residue on and in the units, not to mention all down the intake tubes. This would be, presumably, from improper/over oiling of the filter element. While the sensors hadn't "failed" per se, the oil coating the sensor wires would cause delayed response of the sensor by insulating the thermal transfer across the sensing element. This would result in backfiring, throttle hesitation, and minor drivability issues. A simple cleaning with electronics cleaner and the residue was removed and the drivability symptoms would clear right up. Based on K&N's testing though, I must be crazy to think their filter had anything to do with the problems.
This myth is busted and so are your pathetic arguments.
One final thought... We always enjoy in partaking of a hearty, and sometimes even heated, discussion on a variety of subjects. However, our forum is based on the respect of other members, and as such, insults will not be tolerated. Calling someone's arguments or opinions "pathetic" is not only unacceptable, it's not conducive to argument/debate process. If that type of behavior continues, the consequences will be swift and severe. Keep it respectful, and we'll all get along just fine.
