Old Wed, April 7th, 2010, 01:19 PM
Tuscany FTX Tuscany FTX is offline
Tuscany FTX is on a distinguished road
Actually, I suspect your wheel/tire combination. I think your tires are MUCH bigger than your neighbor's, which reduces your effective gear ratio by a bunch. This is going to make your truck slow off the mark, unless you re-gear to compensate.
If you tell me what size tires your neighbor has, I'll be able to tell you the difference in your effective gear ratios.
AND, I would not expect the TC to lock up at all in a WOT 0-60 run. With that load, the TC is going to stay unlocked to provide torque multiplication.
My neighbor is running the stock(OEM) wheels/tires. They are 275/65/18, which is also what my stock wheels/tires were.
