Old Wed, April 7th, 2010, 10:27 PM
Originally Posted by sniperfolf View Post
Well like it says I am thinking about ordering this chip... Well I've a few questions before i do... how do i tell if i have PMRs? Also then filling our the orderform It asks for vin does this have any indication of Pmrs? It also asks for mod or stock rears... Its an 02 7.3 2wd and tire size should i fill all this out? And when filling out the calibrations it says the stock and anti theft are free so I can just add them to the list? Oh and right now i am running an edge juice with attitude how does it compare?
First things first.
You have an 02 and unless it's had a replacement engine, I will bet my left...well.....that you have PMRs.
The VIN will not tell whether or not it's got PMRs.
You shouldn't have to worry about filling out any of the specialized questions if your truck has nothing more than basic modifications like an intake or exhaust.
How does the Phoenix compare to a Juice module?
Well, to put it in the most simple terms that I can:
There are ZERO similarities between how the two work. The Juice simply fools the injection control pressure input to the PCM, making the PCM think that the injection pressure is below normal so it jacks up the pressure.
The Phoenix actually replaces the PCM's operating code and causes the PCM to make adjustments on all of the inputs.
