Old Wed, February 4th, 2009, 11:12 PM
twintips_17's Avatar
twintips_17 twintips_17 is offline
Let the Mud come!!!
twintips_17 is on a distinguished road
Check the Model Number and Version Number on the sticker. If it's Model Number EEF2400 and Version E3.xx.xx then it's an older model that is not upgradeable and doesn't support torque converter adjustments or downshift adjustments. In those cases, Custom Tuning is the only solution to achieve the desired shift strategy.
The WOT Shifting adjustment won't do you any good except at wide open throttle. (In know, kooky huh? ) However, you should be able to raise the standard shifting to something a bit more suitable for your needs. The Evo should provide enough adjustment to give you a reasonable shift.
Hope this helps.
I have an EEF2100 cuase its an 02 F150. Does that still limit me to the same perameters?:sniffle:
I have a 15050 Ver: 4.7.7 Date of Man 12/7/07
and also
I have a 15050 Ver: 4.7.7 Date of Man 4/7/08
