Old Wed, April 21st, 2010, 07:40 PM
bsdracing bsdracing is offline
bsdracing is on a distinguished road
For the lope tune set up your ICP very low in idle ranges (700rpm) like 350psi or so, then right behind (500rpm and less) take it up to around 1000psi. This by itself should give a pretty good romp. It will take some playing around with to get the desired effect.
As far as smoothing out the idle try adjusting ICP up or down until it smooths out. Also you can lower the SOI a tad and see what that does, and change base idle speed to get it juuust right.
For a smoke tune just lower ICP in the high MFD ranges.
Again this will take alot of messing around with to get right.
PM if interested in a screen shot of my lope tune. I did it just to see if I could, but never use it.LOL
yeah that is pretty much what i was looking for that would be great too if there was a way to say in like a race tune to have it lope like a pulling truck and in like a DD tune or something idle like the 6.0 and yeah I will pm you in a sec thanks alot will try messing around a bit still no burner to try but got alot of other stuff to do
