Old Fri, April 30th, 2010, 07:16 PM
soutthpaw's Avatar
TIT (Tuner In Training)
you can't run glasspack mufflers after a cat as the cat makes the exhaust too hot and will destory the fiberglass in the glasspack muffler, you would need to make test pipes and bypass the Cats or you will be replacing glasspacs quite often.
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
