Old Sat, May 1st, 2010, 11:52 AM
Originally Posted by epowers777 View Post
Ok got a question.
First
I pulled the fuel bowl and its completely apart. Is there any way i can just dip the bowl in something and pull it out to be sparkly clean? There is some types of solvent/ carb cleaner that will make that thing shine. I thought I seen somewhere that you can use malt vinegar as a parts cleaner/ rust remover.
What is the fuel bowl made of? Aluminum?
Yep, aluminum.
Second
I bought the HPOP re seal kit. My HPOP looks new. It has a re manufacture sticker on it and appears that theres no oil leaks. Should I go ahead and pull everything apart and replace the seals??If there are not any visible leaks I would not worry about resealing it. Just keep parts on hand for future repairs/ upgrades.
The 2 wired mesh hydrolic line going to the middle of each head is that the oil line?That's them.
Thanks
See Blue
