Old Sun, February 8th, 2009, 02:34 PM
OneTomcat's Avatar
OneTomcat OneTomcat is offline
PHP Cheerleading Section
OneTomcat is on a distinguished road
I'm probably the one Jack was referring to regarding a Gryphon rebooting itself. I never noticed it resetting the level on mine. It usually just shuts off and comes right back on, tho once in a while it may stay off for a while. One time it didn't come back on until I shut off and restarted the truck.
I have checked all the connections, fuses etc and everything appears tight. I haven't really done much more than that, as we have way too much snow and cold up here, and it doesn't appear to have any negative effect on the way the truck operates. I guess if it's still doing it I'll deal with it in the spring.
I haven't tried changing the screen color but I'll check that and see if we have that in common. Jerry, you didn't say if you have custom tunes or if your Gryphon is stock (nor do I know if it would make any difference) or if new tunes might correct this problem. I don't have mine as of yet (hint, hint, hint, Corey and Bill)
Never argue with an idiot. He'll drag you down to his level and then beat you with experience!!!
'05 F150 FX4 SCAB
K&N FIPK
Magellan Navigation System
Full Boar Performance SIDO exhaust
Gryphon PHP Programmer w/ custom tunes
4UCam wireless backup cam
