Thread: Scaling?
Old Sun, May 16th, 2010, 08:57 AM
Originally Posted by F-127 View Post
From what I've tried, if you copy a map it will only copy the values. If the normalizers are different, I've found myself bringing up the normalizers and doing a "select all, copy, and paste" for the x and y normalizer. And if you load a second file up, looks like it will take the x and y normalizers from the first file.
Ding!! Ding!! Ding!!
Depending on the disparity of the map values as far as the normalizers go, you can end up with some pretty fishy stuff. Remember this?
http://forum.gopowerhungry.com/21935-post11.html
It will actually work out to the computer thinking WFO at 585 A/D counts. Hang on!!!
Some maps aren't as sensitive to changes and will go unnoticed if the map values are transposed without fixing the normalizers.
