Thread: Scaling?
Old Sun, May 16th, 2010, 04:43 PM
Originally Posted by F-127 View Post
From what I've tried, if you copy a map it will only copy the values. If the normalizers are different, I've found myself bringing up the normalizers and doing a "select all, copy, and paste" for the x and y normalizer. And if you load a second file up, looks like it will take the x and y normalizers from the first file.
Seems like comparing files with different normalizers is useless. The first binary's normalizers take presidence over all others, which makes the second and third binary's values BS if the normalizers are changed.
Change the normalizers to make them the same, now values are not represented right. This is aggravating because I see no way to make different files "comparable".
