Thread
Shifting A Little Hard - Possible Mods- Suggestions?????
Tue, May 18th, 2010, 06:05 PM
Longshot270
You could try adjusting the shift firmness (lower for firmer shift/higher for softer). If that doesn't fix it then you may have to talk to Bill so he can figure out what your wanting to fix.
The lift and tires do not require a retune but a regear may need to be on the list because you can adjust tire size/gear ratio in the programmer's custom options menu.
Usefull links:
Searchable DTC list
Gryphon data log instructions
Longshot270
View Public Profile
Send a private message to Longshot270
Find all posts by Longshot270
