Old Wed, May 19th, 2010, 12:46 AM
Some of this sounds like a bad battery issue, but for it to go on so long, doesn't seem possible.
Still, I think I'd have my battery load tested and replaced if the test shows fail. Then, with the ignition key ON, unplug the Edge, wait about 30 sec and plug it back in.
If this doesn't work, and since you have a new battery it may not, you have most likely corrupted the firmware in the Edge. The only cure is to contact Edge for assistance. They may be able to set up a download to correct the issue.
