Thread: Ya-Hoo!
Old Wed, May 19th, 2010, 11:16 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Update time! (thanks for the pointer Cody)
Finally had some down time to do some more trials. Set the ICP desired down some in the lower MFD&RPM area. Then I looked at the ICP map for 65hp tune for OBS 7.3s. Had that map and a few of my variations on the chip for a trial. ICP map from the 65 hp tune seemed the best. There was only 2 quick romps before getting back to normal, unlike before where is was nearly constant until I quit coasting.
Looked at the Super Duty performance tunes for ICP desired after I finished a few trials today. That looks to be like even more in the direction I was headed. I may try that map once with a few in-between versions to see if I can get it all smoothed out. That will require some "grafting" with both the resolution and normalizers different.
Thomas H.
