Old Fri, May 21st, 2010, 09:54 PM
97Fone50, when the programmer and everything is "On" but without the engine running, disconnect the programmer. Wait about 10 seconds and plug it back in. If you hex code shows up you should be good, if not then get back to us or try calling PHP.
Kevin, can you do one update at a time like the firmware then the calibrations? Also are you just updating canned calibrations or are you downloading custom tunes? If it is just canned then dont worry about them and just focus on the firmware.
