Old Tue, June 1st, 2010, 10:44 AM
X JBM X X JBM X is offline
Diesel n00b
X JBM X is on a distinguished road
Check ALL your ground connections.
Especially the body ground that attaches to the rear of the passenger side head and is routed to above the heater box.
Also be sure the chassis ground is good, it is spliced into the ground cable at the end (driver side?) then bolts to the frame.
If they appear OK but problem still persists you can temporarily add your own by using a set of jumper cables from the engine to the battery negative, and from the frame to battery negative. This will prove that there is (or isn't) a ground issue.
Good Luck
This.
It sounds like you have a grounding problem or a short somewhere to me...
