Old Tue, June 1st, 2010, 11:38 AM
Originally Posted by 04FX4 View Post
I know tuners can not cause any damage to the parts listed above, They just have the option to not do any repairs under warranty. They may and try and blame the tuner..I have know intention on tuning my truck I just want the gauges was all, I was hoping that it would not leave a trace of being plugged in was all.
Ah - I totally misunderstood your question! If you do NOT use the Gryphon to tune your truck, there is NO "footprint". The Gryphon is only receiving information from the PCM, not sending it any. You can use it totally without worry. Just take it out before you take the truck to the dealership so there'll be no misunderstanding.
There will be no P1000 code set by plugging in the Gryphon either, in case you were wondering about that. Bill DID say once though that if you use the Gryphon to "clear" an other trouble codes (this is not programming), that it COULD set the P1000 code. However, you also set the P1000 code if you disconnect the battery, so there's no reason a dealer should be suspicious of that, if it's showing. Just tell them you had the battery out.
