Old Tue, June 1st, 2010, 04:39 PM
Originally Posted by SDRANGER619 View Post
Thanks Jack I think I will do that. I was under the impression I shouldn't run the tow tune and now be towing at that moment.
So just so I ensure I have the information correctly, I should continue to use the Gryphon like I usually do. Then after I do my towing and switch back to tune #1 should I send the cable to you guys to look at?
No, I think you will need an RMA# before you send your cable to PHP. I simply thought it would be good to switch to the tow tune now, while things are working so that it will be in place when you need it for towing. It won't hurt to use the tow tune when not towing but, depending on the weight you pull, using a performance tune when towing can be hard on the engine and transmission. So I'd get the tow tune installed while it's still possible.
Then, if the problem you've been seeing comes up again, just get the RMA# from PHP so you can send in the cable. There should be no need to change your tune.
Obviously, if things continue to function ok and you are done with towing, you'd change your tune back to tune# 1.
