Old Thu, June 3rd, 2010, 11:27 AM
cj45lc cj45lc is offline
I put the Vac operated shut-off valve in the hose coming off the head. Valve was NAPA part # BK6601866. Put the vac t in the white line that is in pass side cab just above the carpet that goes to the silver vac cannister, there is a rubber plug in the firewall just to the right of cannister I cut small hole in & ran vac line through. It shuts off the flow to heat core in the max A/C. Made a noticeable diff in cab temp. There are a bunch of diff ways to do this on FTE.
