Thread: PCM Code
Old Mon, June 7th, 2010, 08:20 AM
X JBM X X JBM X is offline
Diesel n00b
X JBM X is on a distinguished road
I'm not quite sure what that means...
In other words, am I going to toast my tranny using this chip, or should I be good to go? I mean, I LOVE the extra power that I'm getting, and the shifts feel great when I'm on the throttle, but when cruising around town at ~35mph when the TCC kicks in, and it does that jerking thing, I don't wanna burn up the trans.
Since I didn't go back to read if I already posted it, I'll try to describe the feeling.
It's like if you're in a manual trans car, and you go to switch gears, push in the clutch, shift, and then hit the gas a little bit before releasing the clutch (almost like you let the clutch out a little too fast when not racing and just dumping it) making the car forward buck a little before slowing down the RPM's to properly engage the gear.
