Old Mon, June 14th, 2010, 06:12 PM
With the key off unplug the cable.
Turn the key on without the engine running and plug the cable back in.
This message appears at the end of a Pegasus update for the 97-03 programmers. These units will not show the "Disclaimer" screen but instead will stop on a "Connecting to Bridge" screen. Incidentally, the "Bridge" is the communications circuit built into the OBD-II cable for the older vehicles (up to 2003). Everything is working correctly.
Simply unplug the unit from the USB cable(BEFORE you hit the OK button), reconnect, and then click OK. At this point though, it really doesn't matter. Once the unit has restarted and has any sort of display on it, the update is complete. You may plug the unit in your truck and start programming.
Pegasus v2.01.0612 and later now states that the "Connecting to Bridge" or"Disclaimer" screen will be displayed after the update has completed.
