Old Mon, June 14th, 2010, 07:10 PM
vadave vadave is offline
vadave is on a distinguished road
Ok, I connected programer to usb cable. Went to pegasus/updates/custom file download. Unit changed colors alot and was programed by pegasus software. When the connecting to bridge screen apeared i unpluged the usb cable, waited 10 sec. after the connection to the programer dropped I pluged the programer back into the usb cable. It reconnected with the pegasus software and I clicked ok. Another screen came up and said programming complete you can now reconnect to vehicle. Took the programer to the truck. Turned key to on position not running and the only thing the programer will display is (connecting to bridge please wait).
Turn key off and the programer will display that message until battery runs dead. Thats all it will do.
I then pluged programer back into usb cable and updated the gryphon programer with new firmware and calabrations that pegasus found. Unit works as it should with canned tunes. If I try to download custom files again, I go through the same process as stated above with the end result a screen that is stuck on "connecting to bridge please wait"
This is on a 2006 f150 5.4l
I now have it working with the canned tunes by updating the firmware and calabrations but if i try to download custom files we go right back to the "connecting" message.
Dave
