Old Thu, June 17th, 2010, 08:53 AM
BigSur BigSur is offline
Scientist
Thanx for the input I'll let Corey know.
88....one last question before I get underway. Hopefully you get this before I drive today. I know I need to bypass the Custom Options Menu the first time and complete the intitial setup / programming before setting any custom uptions. Can I set my custom options immediate after the initial setup or do I need to drive the vehicle for awhile first? I remember you saying that before....that I should drive 50 miles before changing any custom settings. What I'm worried about is the placeholder values being way off while I'm driving...for gear ratio and tire size...since that will affect drivability, shift points, etc. Additionally, the manual reads as if the custom options can be set immediately after initial setup, you just need to ensure they are skipped the first time. What is your take on this? Thanks in advance.
