Thread: Install Success
Old Thu, June 17th, 2010, 01:11 PM
BigSur BigSur is offline
Scientist
I have one additional question...hopefully someone sees this. Is it normal when installing the pod to have to force the right side (when looking at it) down in between the two sections of dash.....in my case, b/w the dark gray panel where the vent is located and the brown leather panel to the right. My pod would not sit flus on the dash unless I made sure the right side was b/w the 2 panels and pushed down to make everything fit flush and tight. When I did this, it caused the 2 dash panels to spread (just slightly), causing a larger gap than normal.
I don't see this as a big deal but am wondering if my pod is not fitting right for some reason. I've seen instructional pics that don't look like any "spreading" was required to get it to sit flush. Any guidance is appreciated.
