Thread: Tire Size
Old Fri, June 18th, 2010, 08:24 PM
BigSur BigSur is offline
Scientist
You would increase TS if your truck's odometer reads lower than actual. However, if the Gryphon speed PID is reading high, then you should REDUCE your TS! As has been said before, the dash speedo will read a bit fast (about 2mph) when the odometer and Gryphon are accurate.
The Camry's odometer can be off too. Everything is fairly approximate. I personally like to use interstate mileage markers (the longer the run, the better) or a GPS. I have a Garmin hiking GPS that shows current speed as well as distance.
Your 2575 figure is correct, however, for a 0.1 mile error in 4.8 miles (About 2%). And, your initial figure of 2522 is what I would have started at too. Personally, I suspect it is VERY close to the right number, Camry or no Camry!
I was looking at the truck speed gauge not Gryphon, so maybe that's right. Why is there a discrepancy b/w the Gryphon and Truck speedometers? I thought the Gryphon was supposed to correct the truck gauge when TS is accounted for. But yes, I'm definitely off .1 mile w/in a very short distance, so I think I need to crank it up a bit. Thanks guys!!!!
