Old Mon, June 21st, 2010, 10:01 PM
As I recall, pushing the [Up Arrow] causes the backlight to brighten on the Gryphon. Try that next time, rather than "rebooting" it by unplugging the OBDII cable. I think the [Up Arrow] cure causes a permanent change too.
Yep thats right.
Does it flicker when you are either cranking or about to? May be a battery issue. If it is doing it because of low voltage while cranking, the alternator will be running by the time you unplug and replug.
