Old Wed, June 23rd, 2010, 07:31 PM
SDRANGER619 SDRANGER619 is offline
SDRANGER619 is on a distinguished road
Does the truck run?
If it does then>>Leave it alone.
Call Bill@PHP.
That's my best advice.
It runs fine, thank goodness I switched to the tow tune when I needed it.
If you unplug the cable form the OBDII port and reconnect (which I assume you're already doing), are you still getting the "Connecting to Bridge" error? This is nearly always an indication of a failed/failing PC board in the cable and will require replacement of the cable.
Out of curiosity, have you had any starting/battery issues recently? More often than not, the cable will fail after having to have the vehicle jumped or some other low voltage incident.
If the error persists, let me know (e-mail or phone) and we'll arrange to have the cable replaced.
Hi Bill,
I've done the reconnect thing and all I get the the bridge message. During my trouble shooting phase of this problems (thanks jack for the tips) I took my battery to the auto parts store to get checked and see if it was bad because of the voltage sensitivity of the cable, battery is a little over a year old and is working fine.
I will follow this up with an email.
Thanks!
GO PHP!
