Old Wed, June 23rd, 2010, 11:46 PM
If you sent your hex code in with the edge your custom tune should be on there.
In the main menu on the programmer, select [Diagnostics] -> [Tech Support] -> [Version Info]. (You can ignore the warning message that will come up). In the newer Gryphons, 04+, the "Calibration Version" should look like "0.x.xxxx" where the last 4 x's are (usually) the same as the Serial Number. If the Version number DOES begin with zero ("0"), you have custom tuned files. If the Version begins with one ("1") though, so it looks like "1.x.xxxx", then the unit has canned tunes, not custom.
Again - any calibration that looks like 0.x.xxxx is a CUSTOM build. All calibrations that begin with "1", i.e., 1.x.xxxx are CANNED calibrations in the newer model Gryphons.
But, any programmer with a Product Number that looks like --> Ex.xx.xx <-- is an older platform unit and the Power Programming Menu display cannot be changed. And, on those units, if the last 2 digits are "99" then it is always a custom file.
So, an older model Gryphon with a Product Number that looks like "Ex.xx.99" has custom tunes too.
