Old Fri, July 2nd, 2010, 09:35 AM
Usually, the lower the shift speeds, the better the economy. However, if you are shifting too early into certain gears while driving around town, you can end up lugging too much or constantly upshifting/downshifting. Higher LBF will usually help while towing to get the turbocharger spooled up a little bit better under load while limiting the LBF will help with economy while just cruising around.
