Old Wed, July 7th, 2010, 09:31 PM
The idle could easily be raised a couple hundred RPM in this tune as well.
What program did you want to replace in order to run this one?
For the most part, you could always leave the idle stock and use this tune....it's not going to advance the SOI farther than stock after 1300 RPM or while the oil temperature is above 80*C.
