Thread: stage 1
Old Wed, July 14th, 2010, 02:36 AM
Originally Posted by mod11 View Post
Installed!!!!First time around the chip wouldn,t work,took it back apart and recleaned the terminals and it worked fine.Took awhile to get it running but when it did it sounded totally different.Drove it around in stock mode for bout 6to10 miles and then bumped it up to 65mode.Now the questions?
Do I start the truck in stock mode?does it matter?
You can start the truck in any mode you desire, but if you have a wisper or lope tune it is best to use them on a warm engine.
Do I run the truck in stock mode with these injectors?or did you compinsate for that?
That is a question that the PHP crew will have to answer, but "stock" normally means stock(ish) power and shifting, just modified for your injectors.
Can I still use the scanner with no harm to the chip?
Scan away! But don't be surprised if you find a P0605 chillin in there, its normal.
I know,I know,should have asked these before it was installed
LAST:coolest thing is when the duallies are lit up and I havn't used the last two settings yet!
See Blue
