Thread: EGR Delete Q's
Old Mon, July 19th, 2010, 07:12 PM
StripperDJ's Avatar
tech man
well after some homework that i had to do with this problem, and let me say i have seen alot of this same problem...even with tuning with some of the lateter strats the egr valve MUST BE PLUGED UP EVEN IF THE VALVE IS A DUMMY !!!!!!!... if the valve is not plugged up the vvt will not work properly and will not let the turbo spool right..do you have the egr valve plugged up ???
Brad Scott PHP
