Old Tue, August 10th, 2010, 01:19 AM
Pocket Pocket is offline
Interesting idea.
What kind of increments were you planning on experimenting with, 2mph, 5mph, etc?
I'm going to try several different ones. I'm finishing one right now that has 3 "tiers" to it. Depending on the gear, the MPH increments between them varies. Lower gears have smaller jumps, higher gears have bigger jumps.
I may change it so that higher gears have maybe an extra "tier" or two than the lower gears, since there's a much larger MPH range to play with on the higher gears.
I also don't have the jumps following the same pedal position. I learned that lesson a while back, when my trans was jumping back and forth constantly between gears as I was holding a steady speed on a level patch of road
Anyway, I haven't even road tested anything yet. Just been sitting down with the tables playing with them. I'll probably finish up a few more tomorrow morning, and burn a couple of tunes to the chip. Then head out and run some errands and see what happens.
