I know it has been a while, but I thought I would give an update as to the truck. Turns out the oil leak was the fitting off the HPOP for the drivers supply line.
I did get to put my computer on the truck and it did not store any codes for the emission light. I will have a big pull again over labor day and will take my computer with to check codes if the light comes on again.
Still trying to figure out what is going on with the truck. The truck doesn't seem to have the same get up and go as it did before. I also don't recall it having that much black smoke when you get on it. When I put the chip back in stock mode, the truck runs like it did prior to the chip.
A work in progress I guess.
