Old Thu, September 2nd, 2010, 11:22 PM
Originally Posted by richardhearn View Post
i figured that out real quick after i put it on lol i guess i was so used to my diesel where i just threw the biggest tune that the fuel system could handle at it and it was good and i forgot about running premium. but its the same thing on tow (level 2) just not as bad and edge specifically says its an 87+ octane tune. i honestly believe the truck is faster in trans only (level 1) than it is in tow or extreme. and now that i actually read the manual i realize why it would run so bad on extreme.
to answer your first 2 questions yes the truck was back to stock, and yes im using fusion
I wonder if you need to establish a "Fusion account"? At this point, I'm in over my head, because I converted my old Edge Evolution to a Gryphon about the time Fusion came out and I never used Fusion with that programmer.
My only experience with Fusion now is with my new CTS, and it needs you to create an account before it will do anything for you.
I DID use the program called "Lightning" when my programmer was still an "Edge" and it worked just fine. You might give that a try.
I WILL say, you're not going to see the HP and torque gains with a gasser that you saw with a diesel. Possibly, you're expecting too much? I noticed a definite mpg increase with the canned level 2 tune over stock though, and the passing shifting was far superior - which was my main concern.
