I just went into the custom programming and it showed that the shift points were set to 5000rpm with max revs set to 5400. I distinctly remember seeing pass this though. Maybe its as you said and I'm just seeing the flywheel freewheeling. Does it usually default to 5000 when you select the customize feature?
Also I was goofing around on the gryphon and noticed it logged my max rpm at 5383. That is a little high for my liking if the TC starts ballooning at 5400.
Long story short, I have the 1-2, 2-3 shifts set to 5000rpm, and the 3-4 set to 4500rpm. I might increase the 3-4 later depending on how it drives. Max revs I have set to 5350.
