Originally Posted by Longshot270
While the light is on try checking for DTCs with the programmer.
No DTC's show up.
Originally Posted by 88Racing
Put it back to stock and try towing, If it happened again then the programmer is ruled out of the equation..
I did that last weekend, the light still came on
Quite frankly the programmer doesn't have anything to do with the abs system.
Yes, I know the programmer has nothing to do with the ABS
I'm wondering if one of your senser wires has a knick or a cut in it.
That might be the case, on a different occasion, I caught the smell of burning wires, but could not locate the source, everything else works fine though.
Back to my main question, does the dealer have to flash my PCM in order to pull up any codes??
Thanks Lee
