Old Thu, September 9th, 2010, 02:19 PM
DND58 DND58 is offline
DND58
DND58 is on a distinguished road
Tiny, on the inboard side of each valve cover, you can see a wire harness connected to the valve cover. You can disconnect this harness, and use an ohm meter to see if you may have trouble under the valve cover.
Test on the pins going into the valve cover to read resistance from the glow plugs and injectors. Getting good contact of the test leads to the pins can be a pain.
G G I I C I I G G
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
Test between "G" and battery ground to test glow plugs. Should be between 0.6 and 2.0 Ohms.
Dean
Dean
2002/F-350
