Old Fri, September 17th, 2010, 05:04 PM
Probuilder's Avatar
Probuilder Probuilder is offline
DIY Man
Probuilder is on a distinguished road
It is a grey cps in it right now. Should I swap it out to see if that fixes the problem?
Or will it not make a difference when actually running?
Should I check the pressures on the ipr, ipc oil pressure, etc?
Thank you and have a great day, Troy Detweiler
I have a '99 F 250 7.3L Diesel w/ a 6 speed Tranny and 4x4.
Mods: Amsoil dual bypass oil filters, Amsoil air intake mod DIY, fuel preasure spring mod(70psi), FU Chip and Burner , 3.73 rear gears, leveling kit (DIY), Stabilizer bars on the rear axle (DIY).
'02 F 350 7.3L, 6spd,4x4,CC, Dually- Just bought 4-15-11
