Old Fri, September 24th, 2010, 02:54 PM
Probuilder's Avatar
Probuilder Probuilder is offline
DIY Man
Probuilder is on a distinguished road
I cleared all codes, reran the tests, KOER and KOEO. This was all done after checking the resistance on all injectors. They all come out the same and with in specs.
These are the new codes that I get with the AE Scanner on my laptop.
P0475
P1280 ICP too low.
Now on the idle I am running a Injection pressure of 481.96 psi and at 2200 rpm it is at 1153.2 psi. Do these numbers sound right?
The truck is the same as before, so no change.
Thank you and have a great day, Troy Detweiler
I have a '99 F 250 7.3L Diesel w/ a 6 speed Tranny and 4x4.
Mods: Amsoil dual bypass oil filters, Amsoil air intake mod DIY, fuel preasure spring mod(70psi), FU Chip and Burner , 3.73 rear gears, leveling kit (DIY), Stabilizer bars on the rear axle (DIY).
'02 F 350 7.3L, 6spd,4x4,CC, Dually- Just bought 4-15-11
