Old Fri, September 24th, 2010, 05:52 PM
Probuilder's Avatar
Probuilder Probuilder is offline
DIY Man
Probuilder is on a distinguished road
number 8 has almost no change to the engine. But the rest cause the motor to slow down and miss worse. So does that mean that the #8 injector is bad?
Also this truck has 342K on it. Would u just replace q injector or should I change all 8?
Can these injectors be changed out with a set from a 97 motor? I have a spare set of those laying around. So it would be a cheap fix for me. This truck is an early 99, build date of 5/98.
Thank you and have a great day, Troy Detweiler
I have a '99 F 250 7.3L Diesel w/ a 6 speed Tranny and 4x4.
Mods: Amsoil dual bypass oil filters, Amsoil air intake mod DIY, fuel preasure spring mod(70psi), FU Chip and Burner , 3.73 rear gears, leveling kit (DIY), Stabilizer bars on the rear axle (DIY).
'02 F 350 7.3L, 6spd,4x4,CC, Dually- Just bought 4-15-11
