Old Tue, September 28th, 2010, 08:59 PM
AussieOiler's Avatar
AussieOiler AussieOiler is offline
AussieOiler is on a distinguished road
Question
Hi there,
We just sent an FU Chip (same hardware as the FU2) to Australia. We sent it USPS Express Mail; it arrived in 10 days to Warana, Queensland.
Your HEX code is just fine, so don't worry about your box code.
Just a heads up, though... something that we hadn't thought of before shipping a chip to Australia... the cable isn't long enough to reach across to the right side of the dash, so it'll have to be mounted in the middle. TS Performance (the company from which we purchase the chips) is going to custom make us some switches with longer cables, but they don't expect to have them in until late October.
G'day Corey,
Thank you for the reply.
Apreciate the comments concerning the 'Switch Cable' and it's length being a possible limitation to mounting position choice.
I've sent the following questions to Scott (I'm presuming he may be the person you are refering to as he is from that neck of the woods)
1. Did you find the mounting of the switch to be somewhat limited due to the cable length?
2. Have you found any drawback from having to mount the switch in the console centre?
3. Corey says that TS is developing a longer 'Switch Cable' and it may well be available late October. Do you think it worth waiting for a longer cable?
With the FU2 Chip, I'm presumimg that the chip will arrive with the requested custom tunes already installed on it.
I guess there will have to be some sort of activation code; but I presume there is no need to download tunes to start with as you do with the FU?
Cheers,
Reg.
p.s: I notice there is a smile of a little Canadian chap happily waving his little Maple Leaf. Is there an equivalent little Aussie bloke happily waving the Southern Cross?
[/SIGPIC] Aussie 2005(US 2003)F-250 SD 4x4 7.3Ltr PS: AIS Intake,Zoodad,Cowl Hood,AIH delete,DIY CCV,PHP FU2 Chip,RiffRaff FRx,HPx & OCR,BTM Exhaust,HD rear spring set,Front leveler spring, Dual Tower shocks front,Tough Dog Damper,ARB Air Lockers Front & Rear,V10 Tranny cooler+OEM Cooler, BD Deep Pan,JWVB,Long Range Fuel Tank,Edge Evo2,VMS In Dash Nav. GVM(GVWR)Upgraded to 5,000k(LT Rated F350+).
