Originally Posted by Mud Digger
ive tried that and i can see my hex code i can change to a different level but it doesnt load it i cant view my codes when they come up but i can clear them and i can change anything once i change my level i can change the level but nothing else and i'm affraid to go to a dif level wiht out using premium fuel dont want to hurt the truck cause i'm not sure if it really changed it or not...i'm not good with computers i'll have to try and figure out pegasus
I'm sorry, but I don't understand a thing you are saying.
You can change to a different level, but it doesn't "load it"? What is the error message?
If you can't view codes, how do you know you have any, and, how do you know you are clearing them?
You say you can "change anything once [you] change the level", but - you said before that the level doesn't change?
And, what do you mean you can "change the level but nothing else"? Doesn't that contradict your statement that you can "change anything"?
The only reason you'd use premium fuel is if you were using a high octane tune. Your truck was designed to burn 87 octane gas - period. Don't go to a high octane tune level if you don't want to use premium - problem solved.
If you're "not good" with computers, you probably should not be using a programmer. You DO understand that it is a microprocessor device, don't you, and, that
you are programming your truck's "computer" with it?
There's nothing really hard about using Pegasus. You just have to be able to click your mouse button. What is hard about that?
Could you possibly have someone who knows how to write in complete sentences explain your problems here? Unless we can understand what is going on, it's going to be very hard to help you.
