Old Tue, October 5th, 2010, 11:57 PM
Mud Digger Mud Digger is offline
Mud Digger is on a distinguished road
I'm sorry, but I don't understand a thing you are saying.
You can change to a different level, but it doesn't "load it"? What is the error message?
If you can't view codes, how do you know you have any, and, how do you know you are clearing them?
You say you can "change anything once [you] change the level", but - you said before that the level doesn't change?
And, what do you mean you can "change the level but nothing else"? Doesn't that contradict your statement that you can "change anything"?
The only reason you'd use premium fuel is if you were using a high octane tune. Your truck was designed to burn 87 octane gas - period. Don't go to a high octane tune level if you don't want to use premium - problem solved.
If you're "not good" with computers, you probably should not be using a programmer. You DO understand that it is a microprocessor device, don't you, and, that you are programming your truck's "computer" with it?
There's nothing really hard about using Pegasus. You just have to be able to click your mouse button. What is hard about that?
Could you possibly have someone who knows how to write in complete sentences explain your problems here? Unless we can understand what is going on, it's going to be very hard to help you.
the error message is the same as everything else it says it does not have a calibration for it
also it says i have codes the check engin light comes on so i go to view dtc's or w/e it will say you have 2 codes or what ever but the screen will be blank, i can hit the clear code button and it will clear them for the time being
i can change the level to any level but i cant change tire size or WOT and all those goodies and when i hit done it wil say turn key off and than on but dont start and when i do that it will go to the loading part and stop and say that same thing it does not have a calibration or w/e but when i exit out of it it says level 1 2 or 3 or what ever level i programmed it for but with out it writing the pcm
and currently i have it set for level 3 and thats how it was set b4 all this happend so ive been putting premium fuel in it since than cause when it does change the level i dont think it actually does it..so problem not solved
no i'm great with computers just not with down loading stuff and using it...
