Old Mon, October 11th, 2010, 10:32 AM
bigterp's Avatar
bigterp bigterp is offline
bigterp is on a distinguished road
Originally Posted by cajunboy2208 View Post
Read on the f150Forum that on 4.6 it does not increase MPG or HP.
But on the 5.4 some said you will get 20-30 more mpg per tank, which is like 0.7-1.1mpg increase.
I am guessing this will only be in the summer time though when you do use your AC.
And as for the HP increase with 5.4, I doubt it would be anything noticeable, all it is doing is freeing up a clutch.
The biggest outcome from this would be to lessen the miles on your water pump.
I would spend no more than 200 on a total setup.
I do plan on doing this mod tho on my 5.4
I'm looking at about $275 with the setup I plan to get. I'm ok with that amount, as it seems to be a quality kit that I can rely on. I'll most likely drop in some UD pulleys at the same time, so hopefully I'll notice a little more HP increase by doing the two mods together rather than just the e-fan upgrade.
2007 Scab-FX4-4x4-5.4L-49,000 miles(Jan. 2011)
Custom Emblem Overlays - Patriot Decals (TERPS) - Krylon Fusion on Tailgate/Door Handles & Stock Fender Flares - 12" Shorty Antenna - Gotts/DVM Mod - DIY Black Headlights - Nightshaded Taillights/3rd Brake Light - XM Radio - SI/DO Magnaflow ExhaustGryphon CS W/ 87, 93 Performance & 87 Tow
