Old Mon, November 8th, 2010, 09:02 AM
Troy,
You need AT LEAST 340 PSI while the engine is luke warm. A HEALTHY engine will usually be in the 370-400+ PSI range. Anything lower will usually cause a miss until the engine warms up or the boost comes up a little bit.
Low compression will usually be accompanied by white smoke from the exhaust that burns your eyeballs if you stick your face in it.
