Thread: F1 code
Old Sat, November 27th, 2010, 10:51 AM
Red, I doubt you were "flashed" - The error code 0xF1 can sometimes appear during programming. Try this:
1. Leave the ignition key in the ON position.
2. Disconnect the Gryphon at the OBDII port.
3. Plug the Gryphon back into the OBDII port.
4. After getting to the main screen, wait 15 seconds for needed parameters to be loaded.
If you still cannot program the PCM successfully, contact PHP for assistance.
I THINK your programmer simply did not boot properly after you got your truck back from the dealership.
AND - please insure your battery is fully charged and that both the truck and the Gryphon are "warm" (now that cold weather is here).
