Old Fri, December 3rd, 2010, 12:06 AM
Thats what I figured but I like to be blunt at times so there is little miscommunication. Even though you still have the edge, go to the website and download the gryphon manual for starters. It has some very good info about many of the parameters you have access to. You should also read the stickies in all the relevant sections...there will be a quiz later on comprehension.
Edit: Here is the manual
http://www.gopowerhungry.com/manuals...02004-2008.pdf
Also, just about every vehicle is different so what works for me probably wont work the same for you. Dont remember who but someone around here was getting their best speeds with the WOT fuel set to 1.6ish while my optimum setting is 1.3-1.5 depending on the weather. Performance at part throttle and WOT can also vary between vehicles and set ups. The only way to find your peak settings is to do your homework and make gradual changes. It wont be an over night deal but it is the safest way to go about it.
