Hmmmm... Not sure what's going on. A couple questions:
1) The first time you went into Custom Options, did you "Load Previous Settings" or did you make initial changes?
2) What are the parameters you modified and what values did you put in?
3) If you make all changes manually, does everything run OK? (I'm assuming from the post, this is the case)
4) When you do "Load Previous Settings" and go through the parameters you modified, do they look correct?
Let me know and I'll see what I can come up with.
Bring back  Windows™ XP and 7.
 Windows™ Vista and  Windows™ 8 is a pain in my a$$!
